Tool for Cropping and Trimming a part of video file
What is the tool to crop part of video file? My current operating system is Windows Xp and I need a software that can possibly crop a part of a video file with format such as avi, wma, mp4 and more. I hope you can recommend the best and secure software application that can edit videos.
Thank you.
Waiting for your support.
Answered By 15 points N/A #184477
Hello Kristin,
So you want to edit videos. There are so many software or application by which you can edit videos. The choice of application among them is depends on your choice.
But, I suggest you to use “Format Factory” as I use this one. I think this the best video and audio editing software as it is easy to use and completely free.
You can download this software from here: https://format-factory.en.softonic.com/download
Hope you will be happy with this one.
Thank You.
