Too Long File Name or Extension
To make a remote back I use a “Gmail Drive”. During the copying process it generates me an error message saying, “File name or extension is too long. ” As a matter of fact, I’m copying a setup suit of Oracle and I’m wondering what if rename its file as it won’t works properly thereafter.
I’m running Windows 7 on my computer system. I’m looking for your kind help and suggestions how to get done with copying without renaming it? Or, can any one confirm on this whether it would have affects on the installation process if I rename files?
Best Answer by
Answered By 0 points N/A #132341
Hello Harold Ruby,
Thanks for sharing your problem with us, to solve your problem please check your disk for the NTFS errors. To check your disk please follow the following steps:
1. Double click on the computer icon present on the desktop.
2. Now right click on the drive that you want to check. Click on properties option.
3. Now click on Tools. And click on check now.
4. Please make sure that you have checkmark the Automatically fix file system errors. Now click on click on start.
I hope this will solve your problem.
