Syntax Error on Power OLAP
I am using PowerOLAP in Assigning a Fact Data security for our company’s database. I encountered a problem when I was assigning a Fact Data Privileges through the Cubes dialog box. See the attached error message.
After I selected a Users or a Group and selected an Access level, I clicked OK where I returned to the Fact Data Security Rules dialog box eventually. I also typed a semi colon (;) at the end, to end the expression. When I clicked the Check button to scan the expression for errors, this error message popped up:
PowerOLAP
There is no syntax errors in the security rules
How can I remove this error dialog box on my screen? Can someone provide me a good solution?
