Sound problem with my Droid Pro2
My Droid Pro2 phone is not playing any ringing tones and notification sounds; even if the sound settings are all okay and the volume is set to very high. I also checked on the Profile settings but it has still no sounds. Can anyone help please?
Answered By 0 points N/A #151538
         Try to use headphone or an earphone, maybe the settings is set not on your phone speaker. If are sure that the only problem is on the software and not on the speaker itself, try to format your computer to refresh it and go back to its original settings. But If the speaker still not working maybe the problem is on the speaker itself.  You need to go to the technician to consult your phone. There is a possibility that some wires are not connected or worse, the speaker is already damaged and need to replace it with a new one.  Good luck.
