Software updates are not available
Hi there,
I got this message while scanning the system for necessary updates and nothing was installed but it says that my device has been modified. The problem is that some apps request my permission to install some updates even if says that none are available. Does anyone have any idea about this ? What should I do ?
Thank you !
About device
Software update
Your device has been modified.
Software updates are not available.
OK
