Setup issue of Windows Live Messenger 2011
Hello everyone, why I can't set up the Windows Live Messenger 2011 and Windows 7 (64 bit)? However, when installing this programs it look runs well, but after the installations nothings happen and the folder is blank. I do not see any failure while installing. So I go to control panel and look for the firewall and turning off and yet same issue (together I installed administration) it's not working. I reboot it certain times but still nothing change. Is there anyone also encounter this kind of bad situations? And I think if you do maybe you should share your ideas. Thank you so much.
