Problem in setting up with Partition Table
Hello Howel,
If your partition manager software reports errors in the partition then it would be best to leave the partitions alone.
If you really need to repartition your hard drive, then it is extremely important to backup all important data to another hard drive before attempting to fix or repartition the hard drive.
Since you say you have already tried several other partition managers with each of them reporting errors, then I suggest doing a zero fill on your hard drive to ensure removal of any partitioning errors as well as to thoroughly test the drive integrity.
You can do the repartitioning during re-installation of your operating system.
