Please explain how to fix bad sectors on flash drive 4GB
30 points
Posted on - 08/06/2013
I have a Flash Drive of 4GB memory and it contains some damaged sectors because some files are damaged but they work fine when accessed from my computer.
The most common solution I found is to change my flash drive.
But also, I heard that I can fix it. So do you know how to fix bad sectors on flash drive?
Is it possible for me to repair it?
