OSD Task Sequence has failed
OSD Task Sequence has failed with the error code 0x00000001 Task Sequence has failed with the error code 0x00000001 when running Task Sequence in WinPE mode. I tried to search the solution to fix this error but couldn’t find a resolution. Have you any idea to resolve this error? Waiting for the solution.
Error: Task Sequence: Re-Build x86-Newbuild has failed with the error code (0x00000001). For more information, please contact your system administrator or helpdesk operator.
