Network meter du meter monitor your internet usage
Network meter du meter monitor your internet usage. Why some downloads seem to take an eternity to complete, or why your e-mail program seems to be stuck in the middle of e-mail retrieval. Does DU Meter alert you of dangerous or unexpected network activity? Does it really helps?
Answered By 5 points N/A #187257
Suppose you want to put a check on your employee or children internet access, then DU meter is the best software for you. You will find that DU meter can put a check on internet usage and puts a limit on the usage. You might have put a condition that above certain file size, the employee cannot attach any file or upload from the email or that system user might have crossed the set limit. This might be creating the problem. However, DU meter does not puts break on unexpected network activity. It just sets a limit. That limit might have been crossed.
Waters Magner
