My Samsung smart TV is not connecting to Wi-Fi
I bought Samsung Smart TV a few months back, it was working perfectly fine, but then it does not recognize my home WiFi, it even fails to detect any WiFi connection! Most shocking thing is it is not showing its own WiFi's SSID. What should I do to resolve the issue? Is there any master reset?
Answered By 0 points N/A #185116
These days most of the devices including Televisions have automatic settings & in built adapter. But some may don't have and need a WiFi adapter to work. Once you get a WiFi adapter you have to set up the Wifi adapter for the first time and then it will be ready to use and connect to a network. The Wifi setup includes network selection an assigning a security key.
