My internet browser ‘Firefox’ installation problem
I downloaded Firefox internet browser 3.6.18 from internet. I installed it on my computer. It doesn't work properly. I wanted to install ‘ad-ons Nodofollow’, but I didn’t found Nodofollow in the tools menu. How can I install ‘Nodofollow’ in the Firefox browser?
Best Answer by jimmytoy
Answered By 15 points N/A #86585
Hi dear,
Your problem about Firefox is not so much complicated. You just do like this, install a new windows with its all necessary functions. Download  or buy a Mozilla Firefox from a right  place. I have an experienced the Mozilla Firefox 3.6 is not working properly, sometime it do not install completely, sometime after installing it does not working properly.
I think the reason about it is the Mozilla Firefox 3.6 has become expired or it does not have new features which supports it. So here I suggest you about Mozilla Firefox 4 or 5 get from it and install it will work in a proper way and it will help full to installing Nodofollow in this Firefox browser. Because Nodofollw 1.1 by Zachary fox is available for the Mozilla Firefox 4.0.
Here jayce from the jayceooi.com will make the installer to work properly in a Mozilla Firefox. Then from that place download new Nodofollow 1.3 plugin. Now install it and restart the Mozilla Firefox. If you want to check the blog either it is do-follow or no-follow,  For this you must right click on any part of web page in Mozilla Firefox  and than click on Nodofollw. You will see there like the Do-Follow links will turn Blue and other No-Follow links turn red. You can see a video for installing it ..
Answered By 590495 points N/A #86586
This software application has to be installed in your computer and added into your browser’s list of add-on. This gives you certain access to a specific website that need this software to play and display certain images and video. To download NoFollow on Firefox Add-Ons, then go to this website.
https://addons.mozilla.org/en-US/firefox/addon/nofollow-advanced/
This provides Search Engine Optimization and website services designed in Tampa Bay, in Central Florida. Install the latest Firefox browser, after their the installation you’ll need to restart the Firefox browser. Click on the Restart button and it’ll open the newly installed software. Turn the page for blog on, then go to Tools, and check the “NoFollow”. Do right click is an alternate steps to perform this procedure.
