MS Office x32 and x64 running in the same PC
Is there really an issue with MS Office x32 and x64 running in the same PC? It seems this is what I came across with my client's PC which has Windows 7 (64-bit) OS and MS Office 2010 Starter pack that seems to be a 32-bit version.
The starter pack only has MS Word and Excel in it. The client needs Outlook 2010 so he purchased a copy and had me install it. However, I came across an error message that stated I can't install it with an installed Office Starter x86.
From my online research, the only suggestion I came across with was to uninstall the MSO Starter package. Can anybody tell me if this is the only solution applicable? Is there anything else that can be done to remedy the situation?
Thanks a lot.
