Microsoft Outlook error “Object name: ‘IndexerNotifyForm”
I am having problems accessing a disposed object. I keep on getting an error "Object name: 'IndexerNotifyForm".
I get this error when opening Microsoft Outlook. I also get this error when I was coding t-sql on my SQL server.
Can anyone suggest a fix to this problem?
I will be waiting for your responses.
Thank you.
Error:
I'm sorry, but a serious program error (Cannot access a disposed object.
Object name: 'IndexerNotifyform'.) occurred.
Would you like to send a bug report (don't worry: you will be able to review all contents before the report is sent)?
