Locating the Windows 8 Pro timebomb
Where can I locate the windows 8 pro timebomb ?
Answered By 0 points N/A #149290
Hi Brian Timothyy,
There are a lot of ways of checking the Expiry Date of Windows OS. You can try any of the below methods.
Open Command Prompt and type the below commands.
  1. 'slmgr.vbs /dli' or 'slmgr.vbs –dli' – Will display Complete details about the License
  2. 'slmgr /dli' – Will show current license Information
  3. 'slmgr /dlv' – Will show detailed information of current license
  4. slmgr /xpr – Will show expiration date of current license
Or You can use the below method
Press Windows Key+R(run) and enter 'winver' and hit OK. This will show the license agreement as shown below.
The given methods will work in every version of Windows.
Hope it helps.
