Kundli 2000 Error “Insert key diskette”
I installed Kundli 2000 software on windows XP successfully. I had this error “Insert key diskette” just after I click on VIEW when I entered all the details. I tried “sysedit”, and config.sys shows INSTALL?=C:KUN2000KUN2000.EXE and also autoexec.bat is blank. I tried installing the program on Windows Vista but the error still occurs. Do you have any idea why this happens? Thank you. I really need to get your help soon.
