Kindly suggest a tool for wsdl conversion to sql database ??
As wsdl is easy to code and if we want to create quick data tables its will be easier if we convert the wsdl objects to SQL create statement. Can anyone suggest a tool that converts wsdl (web service definition language) to SQL database?
