Like to increase the volume on my smart phone
Hello, I would like to increase the volume on my Smartphone but it has reached its maximum.
The Smartphone uses Windows Mobile 5 and 6.
How do I go about it?
I am poor with handling computers and especially software.
Answered By 0 points N/A #161041
Hello there,
There is no way you can modify your mobile speaker above maximum default sound level. The reason behind is. Your speaker is limited to that specific wave strength, and can only handle that defined level in order protects its performance.
However, if you are really trying to push it beyond the limit, well. There is a solution to that and you are to upgrade your mobile's firmware. Firmware is like a computer environment upgrading it will vary with OT performance. You cannot do this procedure alone only authorize a technician has the right to modify that as far as I know. You need to go to Mobile center and upgrade it there.
Upgrading your mobile would only cause you a problem. I don't want you to experience the same frustration as I had when I upgraded my Android LTi50.
Hope this advice helps you.
