I am having trouble with transferring a Calendar in MS Outlook 2003
I am having trouble with transferring a Calendar in MS Outlook 2003, and I hope someone can help me out.
I created a calendar and put it under “My Calendars”, however, when I look at the column header it doesn’t show the name of the calendar.
I want to see the calendar name so as to avoid confusion with the other calendars I created.
I tried several things to solve the problem, and I noticed that this issue doesn’t happen with calendars under “Other Calendars”.
So is there a way of transferring my calendars to “Other Calendars”?
Or does anyone know how to configure MS Outlook so that the calendar names would be seen?
Thank you in advance for your solution.
