How to update a sofware for Linux terminal”sudoapt command”
I want to update a entertain software, however I do not know how to get about the sudo command in Linux terminal, How do I get about this? is there a manual for the sudo commands for beginner that explains the different sudo commands and their interpretation? where can I get this sudo- command manual?
