How to open dwg in acrobat reader?
Hello fellows,
How to open dwg in acrobat reader? My friend emailed me some dwg files and wasn’t sure if I can open it using acrobat reader, I need your opinion or suggestion on the right software that can handle dwg files. I really need to open those files as soon as possible. Thank you.
Chloe Chylly.
