I want to install virtual networking computing to my windows home server because all the people that are related with me always use the same operating system which is windows 7 32 bit. Can you give me some advise?
How to install vnc on whs? And more details about this.
To install virtual networking computing on your Windows Server follow the steps below:
1. Go to http://www.tucows.com/preview/207280/VNC-Virtual-Network-Computing and download virtual networking computing on your computer. Then transfer the setup file to your server.
2. Now double click on the setup icon and start the installation process.
3. Follow the instructions on the screen and install the software on your server. Make sure you check the compatibility on your server. If it is not compatible with your server then you will not be able to run it.
4. After you install virtual networking computing on your server run it from the desktop. It should look like the picture below:
