How to get rid of Error code 1000-0146?
Hi, due to a problem in my Dell inspiron 1150, I ran a diagnostic test holding the function key down and the same time pressing the power button. Then a message popped up showing error code 1000-0146. I am totally confused with the error and could not find any solution. I will be very thankful to you if you can give me any suggestion. Thank you.
