Hello guys,
I have iPhone5 and want to send a 20mb video file into Samsung galaxy S3 Android phone. I tried with Skype, E-mail, Bluetooth and YouTube Ended with disappointment. How do I send large files from the iPhone? I would be very grateful if you give me an appropriate solution.
Thank you.
How do i send large files from I-phone into android phone?
Usually, with an iPhone you can not send anything with Bluetooth to any other mobile phones, if that mobile phones are not iPhones. You can send with Bluetooth to a computer or to another iPhone.
But, you can try to connect a computer and your iPhone with a USB Cable and then transfer that to the computer, and then connect the other mobile phone with that computer and transfer to the other mobile phone.
Hello Shekharsirohi,
You will need to connect the iPhone to your computer and then sync the files into your computer. This is the case where the files were also put into your iPhone through syncing. If they were just copied into the phone like copying into a hard drive of which you won’t be able to browse the iPhone and see files, then you can copy directly into the computer then from there to your android or connect both devices and copy directly to your android. If syncing was the case, then you need to install iTunes to your computer before you can transfer files to the computer through syncing, then to your android.
Hi, I hope this helps.
For a long time transferring files between the 2 operating systems for IOS and android was a problem. A few geeks in Belin made life easier. They created an app called HOCCER, available in both platform's stores, Google Play and iTunes store. It is an app for easy, fast and secure data transfer between gadgets. You can share literally everything; photos, videos, music, and even contacts. Download it and you are good to go.
Let us know if this helps.
