How can I Recover my Data from my Hard drive Back up?
I have been using my external Hard drive Back up system to store my data,but unfortunately i can't explain what happened to it and it got damaged.
Is there any way to retrieve my data back.
While doing data recovery you have to consider which method or software to use to recover data. Other hard drive recovery methods could just cause more destruction by trying to fix the problem instead of recovering the data.
Data recovery PC is the best software to use for this kind of work. It has the right amount of power and it is flexible and easier to use. It also helps in backing up your file in an easy way.
It is also fast and easy to use and manage. So you do not need to worry about data that cannot be retrieved because there is a solution which has passed the test and is recommended for use and further more you need not hire anyone to do it for you because you can do it yourself with ease.
There are a number of Software's out there that you may use to try and recover your files.
Most important you need to establish where the problem is on your drive.
It really doesn’t matter that you might have a powerful data recovery software, but if the problem is on the disk itself, this software will do you no good. Knowing whether the problem is on the hard disk itself or the PCB (printed circuit board) is only the first step to successfully rescuing your data.
If the problem is on the PCB, chances are that this is something that you can easily replace and still use your drive for a couple of more years to come, but if the problem is on the disk platters or the inside of the disk, you may have very slim chances of rescuing your files.
Please try and establish where the problem is. Regards.
If your hard disk is crashed then it is impossible to recover data.
If your hard disk is ok then try it with another computer.
When you will be sure that your hard drive is crashed then you can not recover it.
So for your future plan when you input your data in computer then you have to try another copy to CD or pendrive.
Thank you
