How can I fully remove bandwidth limit DSL?
Hallo!
There seem to be bandwidth limits on all the computers in the office.
This affects all even at times when only one computer is in use.
How can I remove bandwidth limit DSL so that all the computers have free and shared access?
The only controls that should be left are the ones implemented by my ISP.
Best Answer by Davidson Mudge
Answered By 0 points N/A #150271
Hi Gran Wesner,
You can follow these easy steps in removing the Bandwidth in DSL connections.
For Windows 7, Windows Vista and Windows XP.
1. Type GPEDIT.msc into the search field on the start menu. (NOTE: Windows XP users type it in the Run Box also found in the start menu.Under Computer Configuration collapse administrative Templates, Network and then click QoS Packet Scheduler.
2. Under Computer Configuration collapse administrative Templates, Network and then click QoS Packet Scheduler.
3. Double-click Limit reservable bandwidth on the right pane.
4. Click Enabled.
5.  Enter 0% in the Bandwidth limit drop box menu below.
6. Click Apply.
You can also create a registry file to execute the same command:
  1. Open a notepad.
  2. Type this registry command:
         Windows Registry Editor Version 5.00
         [HKEY_LOCAL_MACHINESOFTWAREPoliciesMicrosoftWindowsPsched]
         “NonBestEffortLimit”=dword:00000000
  1. Save the file with a .reg extension.
  2. This changes to Command Icon and then double click to execute the code.
Answered By 0 points N/A #150272
Hi Gran,
There are two ways to do this, the first one is the one described up.
The second one :
Windows menu > control panel > Network and internet > Network and sharing Center > wireless Network Connection
A new window will open, then click on properties ( on the bottom in the left)  another window will open you should click on  Configure > Untick "QoS Packet Scheduler"
a dialog window will ask you if you want to uninstall QoS Packet Scheduler, if you keep it or uninstall it gives the same result.
you will upgrade your bandwidth of 20%
