How can i do lion sync folders between computers on Mac OS
I want some help in Mac lion sync folders between computers. I want two folders in two computers both using Mac OS X Lion to be synchronised. It means the change in contents of folder in one computer should reflect in sync folder in the other computer. How can id do this ? Need some help urgently.
Best Answer by Waall Mike
Answered By 0 points N/A #138703
I will recommend you rsync,it is a great utility that will synchronize the folders easily. Really easy to install and use on your computer. Kindly look at the tutorial  here is the link
https://everythinglinux.org/rsync/
The rsync utility is common to Linux and Mac OS X. I hope this rsync utility will help you.
Regards
Answered By 270 points N/A #197822
Hello Albertowfrazier,
There are several third party programs that you can download to help you with your syncing problem and the best bit, some of them are free. FileSync is a freeware so its definitely worth a try, SyncTwoFolder would work with Windows PC and Mac and SugarSync will work to help you sync files from your mobile. Hope this tools will help you.
Waall Mike
