Gather Knowledge About HP Compaq Dc7800p Small Form Factor
Hi. I am not very comfortable with the software and hardware related stuff. I would like to know about the system requirement and steps for installing the OS for HP Compaq dc7800p small form factor drivers. Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #169634
Hi. The system requirements include a 1 GHz processor (32-bit or 64-bit), system memory of 1GB, graphics adapter, 24GB hard disk space, DVD-ROM drive and 1.5 GHz CPU with 2GB system memory. For installing the OS for HP Compaq dc7800p small form factor drives, first change the order of the boot in the F10 setup and make the optical drive as the first boot device. Next, insert the OS DVD into the system and turn on the power of the system.
Next, instructions which appear on the screen need to be followed for the installation to take place. When asked, click on custom installation option and download the drivers from MS Windows update after getting connected to the internet.
Hope we helped.
Answered By 590495 points N/A #313584
Downloading all the drivers for the HP Compaq dc7800 Small Form Factor PC is not a problem because it is always available on the manufacturer’s website. To download the drivers, you have to know the operating system that’s running on your computer. To download the drivers, go to HP Compaq dc7800 Small Form Factor. Here, select your correct operating system.
The software for HP Compaq dc7800 Small Form Factor are available for Windows 2000 (32-bit only), Windows XP, Windows Vista, and Windows 7 both 32-bit and 64-bit. Just select your correct operating system from the dropdown list then click “Change” to display the downloads. Download and install all the available drivers for your computer.
