File that cannot be deleted
I have two issues with some files. I want to delete a file, but whenever I try to delete it, the computer response is “the file cannot be deleted because it is being used by another program”. I have no other running program, that is why I am confused which program is preventing me from removing/deleting the file.
Second issue is that I have a file that after I delete and exit the folder which contains the same file, if I go back to the folder, it is still there. I will again delete it, but it doesn’t go away. The file has no use for me because it contains no data.
