Express 2013 for Windows With Blend Setup Blocked
Hi there,
I just installed on my PC Microsoft Visual Studio Express 2013. I’m running on PC Windows XP (x86) SP3. My PC is up to date and the error says the I need a newer version of Windows. Any solution for this error ? How can I installer Visual Studio properly ?
Thank you !
Visual Studio
With Blend
Setup Blocked
Correct the following problems and then run setup again. To learn more, you can review the list of common issues and workarounds or examine the log file.
This version of Visual Studio requires a computer with a newer version of Windows.
