Error when using a debugger tool
Hi Gurus,
I was trying out a debugger tool when this error message appeared, see below.
I have searched the web, and it seemed that no one has ever experienced this yet so no one has blogged about it and even given a resolution to it.
Need to resolve this ASAP.
Please help me!!!
Thanks in advance.
A problem caused the program to stop working correctly
Microsoft Windows
Test Default Debugger Tool has stopped working
A problem caused the program to stop working correctly. Please close the program
Close the program
Debug the program
Answered By 0 points N/A #91639
Now there is available the solution of your problem for Microsoft, But only it can apply it to systems that are experiencing the specific problem.
Well, if you are not severely exaggerated by such a specific problem, we recommend that you wait for the next Visual Studio 2005 service pack that contains it. You can contact with the Microsoft Product Support Services to obtain resolution of this problem.
For a complete information regarding to the Microsoft Product Support Services you can visit the link, Download Link, You must be notified about the charges that are ordinarily incurred for support calls may be canceled if a Microsoft Support Professional determines that a specific update will resolve your problem.
The usual support costs will be applied to additional support questions and issues that do not qualify for the specific update in your question.
