Error Starting Program – A required .DLL file, SAMLIB.DLL, was not found
My machine has encountered a problem. I received an error message while installing a program.
I received the same program during un-installation. I have no idea for the error message.
Have a look at the error message below.
How can I get a solution of this problem?
Thanks in advance.
A required .DLL file, SAMLIB.DLL, was not found.
Best Answer by
Answered By 0 points N/A #192887
Hi Jhon Anderson,
Thanks for sharing your problem with us, it seems that some of registry files are missing from your computer. You can download the missing registry file from the Microsoft official website. Try to repair your registry with the help of Registry Repair Tool. Just download and install the registry repair Tool and scan for the corrupted registry.
I hope this will help you.
Answered By 0 points N/A #192888
Hi Jhon Anderson,
Samlib.dll is direct link library essential to windows for security purpose blocking malware and spyware. You can retrieve it using system restore. Just restore your system to earlier time or restart your windows and before windows boot again you must press F8 and select Last Known Good Configuration. And if both methods don’t work just visit this site:
