Could not create image buffers in After Effects CS3
While rendering a composition with After Effects CS3, I received an error message. It says, “Could not create 8935 x 9152 image buffers”. What does it mean? Have you any idea for the error?
Please help me solve the problem.
Thanks for the solutions.
Answered By 5 points N/A #132813
Open the CS3 and click the second tab of 'edit' on the upper ribbon. Then click 'preferences' and at the last 'general'. Pop-up will open in front of you and then click the forth option that is 'performance'. Increase the memory usage of Photoshop according to the RAM of your system. Let the Photoshop use 80% of system memory. I hope it will solve the problem.
Please view the steps below in the form of images:
If the above procedure doesn't work please increase your system memory and it will solve your problem. If it is 2GB make it 4GB.
