Cannot open programs or desktop icons
I am having a terrible time with my computer. My computer got recently infected by a nasty spyware. I was able to fix it by installing and running Malwarebytes. I am now having a different problem. When I try to open icons on my Desktop and under All Programs, the programs always try to open within AOL. I am getting the message that says:
AOL
“The file may not be supported by AOL, AOL will try to open it as a text file if you choose to continue”.
When I click the YES button, it opens on a notepad with gibberish content. I tried re-scanning the computer using Malwarebytes thinking that the computer might still be infected but with no luck. I am using a laptop running Windows 7. Any ideas?
Mark Peterson
