Application download to fix my driver USB per htc cruise problem
Hi, everyone!
I own an HTC Cruise and whenever I connect it to my PC to sync, my Computer becomes blocked. It is until I disconnect my driver usb per htc cruise that my PC comes back to life. I have learned that an app called SD split could fix this, but I think it is no longer out on the market? Any other application you could recommend?
Answered By 0 points N/A #153535
Hi there,
If you are having a hard problem when you are connecting your HTC phone to your computer, maybe there is a problem with your HTC Sync Manager.
You have to download a compatible HTC Sync Manager and install it to your computer. And your HTC to computer connector cable must be working properly.
You can download an HTC Sync Manager here in this site: http://www.htc.com/in/support/
And also this, http://htc-pc-suite-07.pc2.software112.com
