All about changing theme in windows 7 starter.
Hello Experts,
All about changing theme in windows 7 starter. Is it possible for me to change my windows 7 starter theme? For I know that this operating system is not that enhanced by customizing the features but if there are some way that I can change themes and download from the internet for free well I hope you can help me by teaching me what to do.
Thank you.
Best Answer by Smith Thompson
Answered By 5 points N/A #172511
Yes it is possible to change your Windows 7 themes. Just go to this page and select the theme you want and click the download link below each picture. After the downloading process, just run the installation and it will change your Windows 7 theme automatically.
Window 7 Theme
Answered By 10 points N/A #172513
You can change windows 7 theme easily. It is as easy as one to three. You just need to download it form the network or put a theme cd you want to install and double click the theme install and then your theme will automatically placed in Control PanelAll Control Panel ItemsPersonalization or follow this path to set a theme.
Smith Thompson
