Adobe Application Manager Update Failed
Hi everyone,
I have installed Adobe Application Manager to update my applications in order to work properly. This morning I tried to update my adobe applications but an error shows up “Update Failed”. Can I get any solution to fix this issue? It would be really appreciated.
Update Failed
Updates could not be applied
The error log file may help you in identifying the problem. Then, try updating again. If the problems persist, contact customer support for further assistance.
