Archive
In adobe Premiere CS6, how can I find the keyboard shortcuts? How can I customize and load keyboard shortcuts? What are the uses and functions of the menus application, panels and tools? How can I delete the shortcut created? What is automatch time in audio preferences? What do you mean by linear keyframe thinning? What do you mean by minimum time interval thinning? What is the supported audio track in CS6? Does it also support higher or lower than that?
Thank you!
I would like to ask what is the use of Adobe Story? What is Adobe OnLocation? What is the use of it in CS6? Can you provide proper way on how to create and open a project in Adobe Premiere CS6? How can I add titles in CS6? What are the common transition effects I can use in this software? What are the additional transition effects added in this software? Can you provide it to me and what are the outcome of using this effects? Where can I emulate audio and change the properties and...
Read moreI would like to ask something about Adobe Premiere CS6. What is the importance of looking in to the timecode and what is the use of it in video editing? How can select the format of time code? What are the steps on achieving this in my project? Can you provide me step-by-step instructions on how to do this? What do you mean by Shot and or take in CS6? What is the definition of it and what is the main function of this in video editing? Please show me how to recover this problem properly...
Read more
I would like to ask few things in Adobe Premiere CS6 before I continue to my next project? What is media, video and audio duration? What is the difference between media and video duration? What is the functions of Video usage and audio usage? What is tape name in this instance? What are the uses of comment, log note and file path in video editing? What are the differences of these three? What do you call the name entered through the Capture panel or the Edit offline dialog box?
Read more
I am just learning ways to edit in Adobe Premiere CS6. Can you provide me instructions on how to edit the display of columns? How can I rearrange the columns and how can I change the width of the column? How can I sort by a column? Please show me how to add column in my project? What are integer columns? What are the different types of columns that I can use in my project? Can I change this in a list view type columns? Please expound the uses of the mentioned options above and...
Read moreI am just learning new ways to work with Adobe Premiere CS6. I want to know how to hide and show thumbnail viewer? Please enumerate the different ways on how to do this so that I have different options on doing this in my projects? How can I sort items in my Premiere CS6 projects? Please set me a sample or instructions on how to make this work or be resolved? What is the use of tool tip in this software? Does provide instructions on how to go with the projects or rather...
Read moreI am just learning Adobe Premiere CS6. I want to know more things that can be helpful for me. What are the options available in the project panel? What is the use of Automate to sequence? What do you mean by scrubbing? How to change the view from one view to another? Please prepare me a sequence and give me necessary details to do this? What are the available menus entailed in doing and achieving such manipulation in this software? Thank you very much and have a nice day!
Read moreI am just new to video editing and using Adobe Premiere CS6. What do you mean by alpha channel? How can I change the display mode? Can you provide me a step-by-step instructions on how to do this? What do you mean All Scopes in CS6? What about Composite Videos? What do you mean by that? What is YC Waveform? What do you mean by vectorscope and what is the use of this in editing any videos? What is the meaning of YC wave/YCbCr parade in CS6? Thank you!
Read moreI would like to know more about the properties of monitor in adobe Premiere CS6. What do you mean by view safe zones in CS6? What is the differences between action safe zone and title safe zone? How can I choose fields in the source and program monitors? Can you show me a step-by-step instructions on how to do this and how to achieve it in my project? How can I save my project? Can I copy it to my external device? Where can I find it in my window? Please help...
Read moreWhat is the use of Source Monitor and Program Monitor? What are the zoom level available in the options? What is Magnification? Can you show me a step-by-step guide and instructions on how to do this? What is Dropped Frame indicator in CS6? What are the details can be used in Info Panel? What are the definitions and uses of each? Where can I find it in my window? What if I accidentally close it? Is there any way that we can pull it back and open it again? Please help me. Thank you!
Read more
