Archive
Is the browser available in windows phone 8, iOS, Android? Where is it actually developed? Is it supported Html5? What is “out of the box” features, it has? Can I save any website by username and password? Is there any add block facility? Can I log same website with different account? How does ‘Snap’ feature work? Can I adjust brightness of the screen? Describe about its security. How many bookmarks can be added into this browser? What is cloud download feature on it? Thank You
Read more
Can PSPAD be useful for HTML code editing? What is TopStyle Lite? How does TiDy library work? What is Hex editor function? Is there spell check function available? Can I code C, SQL, PHP programming languages? Can I edit files directly from the web by using PSPAD? Is it supported by the APACHE server? Is there an auto correction features available? What is a macro recorder and how does it work? Which browser is supported to preview of HTML code? Thank You
Read more
Which language is used to develop MongoDB? Is MongoDB and BSON similar?How is it related to JSON? What is a NoSQL database system? Can I create an Index of any field by using MongoDB? What is the advantage of File storage system in MongoDB? What is GridFS? How does mongosniff work? What is Mongo Management Studio? What is capped collections? Can I use Aggregated function such as order by, group by? How is it different from Mysql database? Thank You
Read more
Which graphic processor is used in Apple Mac Mini MC815HN/A? Describe about RAM quality? Which operating system is included in it? Can I connect this to the big screen of my home? What is the storage capacity available? Is any mouse available with this? Can I Install Skype or any IM application into it? Is there any charging system available? Can I install multiple memories into it? Can I grab photos and videos from digital camera? Thank You
Read more
What is Clone and how does it use? How to share a map in my network by using FreeMind 1.0.1 software? Can I restore zoom and last selected nodes? How to create location based mind mappings? What will be done to press Control-Q? What is the point of interest (POI) and to use this? Is there a workplace for internet research using Google? Is there opportunity for spell check? What are disadvantages in it? Thank You
Read more
What are basic drawing tools available in it? Has it any web element, such as Table, Hyperlink, Text? Can I use Div here? What are drag and drop shapes? Is there checkboxes, radio buttons, combo boxes available? How can I change the button name, text or color property? Can I export the document to Pdf, Png, and JPEG format? How to use Cliparts into it from the Internet? What is Diagram Drawing Support in it? Is it windows based software or Can this use any other operating systems? Thank You
Read more
What is multi-IM client in Trillian 5.5.0.19? How is it differing from Skype or any other IM? Can this install on Android phone? Can I create a shortcut icon on the desktop and is it kept on browser toolbar? How many social networks and IM can add? Is it freeware software? What is Handy Contact List included in it? Can I see full mail preview and doing activities like delete, send etc.? Is there any essential additional feature? Thank you
Read more
Is the software included Unicode support, ReplayGain support? Is it supported AIFF, Musepack, Speex, AU, SND audio formats? What is Gapless playback included in it? Is it supported ripping Audio CDs? Where is its difference from Winamp? Can I organize equalizer differently? Can I import, visualization in it? Can I convert any other audio file format? Can I set up a keyboard shortcut on my way? Can I create songs library? Is Foobar2000 1.3.8 supported on vista operating system? Thank You
Read more
Can Code Compare 4.0.77 integrated with TFS, SVN, Git, Mercurial, and Perforce? Is it opening source software? Can this Folder be compared and is any merge facility available? Can I integrate with Visual Studio? How does this show compare code line? What is Intellisense in it? What is 2-way text comparison and 3-way text comparison? Is it supported multiple languages such as C#, Java, C++? Can this support Javascript and PHP? Can this software install on Mac operating system? Thank You
Read more
How do Symmetry tools work? Which operating system and web browser are needed to set this up? Is any specific graphic card needed to install this? What is disk space and RAM capacity needed? What is new facility available in Grab brush? Can I send a Maya model to Mudbox with the details? Can I export any image format file? What are the new features available? Can I install any plugins into it? Thank You
Read more
