Archive
I would like to ask what could be the possible reason why my hard disk keeps on showing that it cannot continue with the format of this drive? I bought this hard disk just few weeks ago and this is the first time that I am going to reformat this drive. Can you give me instructions on how to resolve this issue? Can you tell me what are the possible causes of this problem? Can you provide me alternative ways on how to eliminate this error in my computer?
Thank...
Hi!
I am using Windows 7 in my laptop. I am using also yahoo mail with this. I didn’t have any problems when I am using Windows XP. I just upgraded my operating system few days ago. This is the first time I received this message. It showed error “800ccc0f.” Can you tell me what is the meaning of this? What could be the possible cause of this problem? Can you give me instructions on how to resolve this issue? Please give me alternative ways also. Thank you!
I heard a new software about saving you from error message in Windows platforms. Do you have any information about this software? May I ask also about the error Goblin? What is that for? What are the best features of this software? What are the system requirements of this software? How useful is it for me? Can you provide me on how to properly install it with my desktop computer? Can you give me additional information about this software?
Thank you!
Hi!
I just recently upgraded my system from XP to Windows 7. I don’t have any issues with it yet. I just want to know how to disable error reporting with this platform? Can you provide me a detailed instructions on how to achieve this? Can you provide me also alternative ways on how to do this with Windows 7? What are the effects that it might brought once a disable this function with my system? Can you give me insight what are the best options rather than this? Thank...
I just recently bought this scanner. I thought that it is already plug and play device. Can you help me how to install this properly? It is not showing in my desktop or any other devices connected with my computer. What is the use of Acrobat ProX with this device? What are the software that I can link with this scanner? Can you give me instructions on how to do that? Can you suggest more alternative ways on how to resolve my problem with this scanner? Thank you!
Read more
Hi!
I am planning to buy and install a new software with my PC. I am thinking of installing Virutal DJ Prophet.Can you tell me something about this software? Can you tell me what are the specifications of this software? Can you tell me how much is it? Can you give me instructions on how to properly install it with my computer? What are the pros and cons of this software? What are the benefits and features of this mixer? Thank you!
Hi!
I am juts new hear. Can you tell me something about equalizers in computer? I would like to ask about FabFilter Pro-Q 2. What are the best features for using it? What are the system requirements for this software? Can you give me what are the special features of this software? Can you give more information on what are the pros and cons of this? Which platform will it work? Can you tell me what are the supports that I can get if there’s any problem with it?
Read more
I saved a project few days ago with this software. I wasn’t able to use my computer for at least 2 days. I did not check my projects since then. I tried to launch my saved project and it showed me message “'missing plugins.” Can you tell me why this happened to Cubase 5? What could be the possible cause of this problem? Can you provide me instructions on how to resolve it? Can you give me alternative ways on how to eliminate the problem?
Thank you!
Hi!
I need your professional feedback about my plan. I am using Windows 8 now. I am planning to install older versions of Adobe Photoshop. Can you give me information about this? Is it possible with my platform? Can you give me instructions on how to do this with Windows 8? Can you tell me what the required software are and plugins that I need to download so I can make it work? What are the possible problems that I might face if I will do this?
Read more
Hi!
I am just new with computer programming. I recently installed also Visual Basic 2013. I was able to use it for at least 2-3 weeks. When I turned on my computer and launched this software it posted me message “The application cannot start.” Can you tell me what could be the cause of this problem? Can you give me instructions on how to resolve this error? Can you give me alternative ways on how to resolve it and to avoid this from happening again?
