Archive
I have a 32 bit system that I wanted to upgrade to 64 bit, the problem is that I have large files that I consider not to loose in partition C and I wanted to know if there is way to upgrade without necessarily formatting the entire drive? Can the upgrade work with all the associate window programs like media player?
Read moreI have a Linux mint system that has a dual boot with windows and I cannot locate the windows files to boot, How can I repair the boot files in the system to correct for both? Will it damage the other? What are the risks involved? I want to be able to connect to both systems
Read moreIs it possible to increase the processor clock speed and make the clock speed run faster? How can do this and is there any risks involved? I want the performance of my machine to go up? How can I know that the maximum clock speed has been attained and how can I prevent failure incase of overclocking?
Read moreI have an image that was taken from a low resolution camera, I wanted to improve on the resolution of the picture. Is there a way/ software that can increase the resolution of the image and make it better? I do not mean photo enhancements, I want to bale to retain the proportions of the image.
Read moreI have a web cam that seems not to focus clearly, I have tried to make the software adjustment for sharpness but it still doesn't work, How can I increase the video frame rates so as to make the software work with higher resolution.? Is this possible? The camera is a 2.0Mp camera
Read moreI have Geogebra and I have been trying to get probability functions but I'm not able to, how can I use it to get Z probability functions? Is also have a problem drawing 3D shapes in this software, is it possible to section a drawing like in CAD to show for dimensions?
Read moreI have a printer that i would like to have a Linux support to enable scanning, How can I install the scanner in Linux. I have tried to run the scanner in Linux but it will not even detect. Is there a debian version of the scan driver available for download? Can I get to scan from the network using this scanner in Linux?
Read moreI have a card reader with full functional but I have a micro SD that cannot be identified. I have tried to use the internet card reader in the modem but it functions and does not work in the card reader. What could be the problem? is it possible that the card reader is faulty? How can one a certain that the reader is faulty and what repairs measures can I use?
Read moreI have a HP laptop that I have used for a while, however lately the battery icon does not indicate and this has been a reason for concern because I cannot know what charge levels the battery is while operating the laptop. How can this be rectified? Is there a way that the battery can show progress of drainage other than through this icon?
Read moreI have a 6 cell laptop battery that seems to be overheating while in use, even after removing the charger it still overheats. Could this be a sign of a short circuit? What is the remedy for this, I cannot put the laptop on my laps while operating for I fear getting burns. Could this be a battery problem?
Read more
