Archive
Hello All,
I have been trying to get some images scanned with Paint and Adobe Photoshop CS3 and my scanner refuses to work. It keeps giving an error message saying that the Twain source could not be opened. I am using a laptop and the USB cable is directly connected to the USB port. I thought I’ll test and see if this is an issue with the USB cable and tried out another cable. But this too gave me the same error. Now I decided to have a go at uninstalling the software. To do this, I unplugged the scanner...
Read moreHi,
I recently downloaded and installed the Revit 2014 30 day free trial version from your website. The download and installation completed without any issues. But when I try to open the application, I end up with an error saying that it was not able to start correctly and that it must be closed. I thought this might be an issue with improper download of the installer and tried to uninstall the software and then reinstall it. But even after reinstalling, I am still not able to open the application. I have tried using three different browsers for downloading...
Read moreHi,
I am having a problem with importing WMV files into After Effects CS4. I get an error message reporting file not found with error code (-43) (3::40) for any WMV file I try to import. This happens with every single file I try to import; even with files created using After Effects. I am able to import these files with windows movie maker but After Effects fails to import them. I am using normal output settings 1280x750. I also tested using an AVI file in After Effects and rendering it as WMV. But once it is rendered as WMV,...
Read moreHello,
I am encountering a strange problem of late. Every time I attempt to save a new image file or save an existing file replacing an old saved state to the new save, the file gets corrupted and can longer be opened. It gives me an error code 43. There is a problem with the PDF files as well. When attempting to save a new PDF from Adobe Illustrator, the PDF just don’t show up in the initial save. It seems to like a lengthier route and if I try to switch out of this folder where PDF is supposed...
Read moreHi All,
I recently installed AutoCAD Mechanical 2010 and ever since I am unable to launch this application. Every time I attempt opening, it crashes with a Fatal Error message. I tried to uninstall and reinstall the software but this effort did not seem to work. Then I proceeded to do a clean uninstall of AutoCAD following the instructions given on AutoCAD support. I logged in as administrator and disabled the antivirus software. And then I deleted all the related files pertaining to AutoCAD 2010 for my 32 bit windows vista machine. Finally, I opened the system registry and deleted...
Read moreHello All,
I tried burning files using DVD-Video mode on Nero Burning Rom 7.0.1.2 after successfully creating some backups with DVD Rebuilder and I get this error informing that the DVD-Video file reallocation failed and the DVD created might be unplayable. It also says one or more VOB files were not present in the folder. I thought I’ll try to burn anyway and clicked ‘yes’ to continue. I t gave me a warning of Nero’s compliance being ignored and burned the disk. Now here is a surprise- ‘The disk plays perfectly!!!’ Though, I never expected it to play. So what...
Read moreHi All,
I tried out auto-blend in the Photoshop CS6 beta version and received the error message ‘Could not complete the Auto-Blend layers command because of a program error’. There were promises of many issues being fixed in the alpha version and so I went ahead and installed the official version today after uninstalling this beta version. This is a fully registered version but the problem occurs even in this version. I had 4 JPG image opened and auto-aligned as layers. But when attempting to auto-blend, this error message shows up and it stops blending. What do you think is...
Read moreHi Everyone,
I am not able to import a SketchUp file into 3DS Max 2014 for rendering. I created this cube in SketchUp 2013. After completing the work and having split it into layers, I am trying to import a Google SketchUp file into 3DS Max. I saved it with the normal SKP extension in Sketchup. And then I opened up 3DS Max and chose the import option from file. But now I get a ‘reader terminated unexpectedly’ error message. Then as a workaround I tried saving the SKP file as version 8 and tried importing it into 3DS Max...
Read moreHello,
I recently downloaded and installed the Actor X plugin for 3DS Max 2009 32 bit version. But after installing this, whenever I try to launch 3DS Max, I get missing DLL error message. I checked and ensured that I had downloaded the right version. But even after trying several times to install, I still get this error message. I had also attempted downloading the 64 bit version and installing it. But this too doesn’t work for me. I then attempted using different browsers to download the installer and tried again. But this problem still keeps happening. Is there a...
Read moreHello,
I have been trying to get my camera RAW working but until now did not have any success. I installed Bridge CS6 using InDesign CS6 and it has installed the 32 bit version on my windows 7 64 bit version. This I thought is likely as InDesign is based on the 32 bit version. I tried running InDesign CS6 and it worked perfectly. Then I tried running Camera RAW using Bridge and I receive an error stating that the Camera RAW editing is not enabled as it requires a qualifying product to be launched at least once to enable...
Read more
