Archive
Normally, when I am taking a screenshot on my Mac PC, I just use the Command + Shift + 4 method and it works fine. But now, when doing that process, an error showed up stating that I cannot save my screenshot. I never change anything on my computer nor installed anything that might be interfering. I tried to restart and make a screenshot again but it still failed. Why am I having an issue with the saving location? How can I fix this?
Your screen shot can't be saved.
You don't have permission to save the files...
Read moreHello,
When I want to run Global Agenda with steam I got this error, when I want to run with SteamMapps the same error appears. I have contacted the GA online support and what they said to me doesn’t work. Please, can someone help me to repair this error ? Why I have this error since from my last play it worked without any error ?
Thank you !
Global Agenda Launcher
Unexpected error:
System.XmI.XmlException: Root element is missing. at System.Xml.XmlTextReaderlmpl.Throw(Exception e)
at
System.XmI.XmlTextReaderlmpl.ThrowWithoutLinelnfo(String res) at System.Xml.XmlTextReaderlmpl.ParseDocumentContento at System.Xml.XmlTextReaderlmpl.ReadO
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xmli(ml Document.Load(Xml Reader reader)
at System.Xml.Xml Document.Load(String filename)
at
Hirez.Utilities.HirezConfigSettings.LoadConfig...
Read moreHi,
I have bought an original game with steam for PC and installed them. They meet my system requirements and is compatible with Windows 7 (x64). When I want to run the game this error appears and I don’t know why it doesn’t work since is an original game. Can anyone help me to install my game properly and run it using the steam ? Also, please tell how can I prevent this happen in the future with other games ?
Thank you !
File exception!
File exception:
Exception in: virtualfilesystem.cpp, line: 624. Description: The system cannot find the file...
Read moreHello All,
I recently purchased the AutoCAD 2010 Professional software but have not succeeded in installing it. The installer proceeds to launch but soon it reports a failure to copy the files and halts the process. Though it gives a try again option in the error message, it did not help me. I tried installing several times and finally gave it up. Please find attached a snapshot of the error message that comes up during installation. I have administrator access on this machine and tried disabling my antivirus while installing. But this did not help me. I also ensured that...
Read moreHello,
I have some problem in running this game which worked fine until this morning. It seems like being a problem with steam. I have waited for 2-3 days, maybe it will be fixed, but not happened. I have checked all the settings again and nothing is changed. Is anyone available to help to fix this error with steam and tell me how can I prevent this in the future ?
Thank you !
No game ownership on steam
You’ve started game under a steam account, but that account does not I have The War Z game ownership
OK
Read moreHello experts,
I have installed this game properly, and when I want to run in I am getting this error message. I have uninstalled the game and installed again, but still getting this error. Can anyone help me to fix this game ? Why I can’t run it, I meet all the system requirements and still getting errors.
Thanks !
Alan Wake’s American Nightmare - Error
Multi-sample antialiasing not supported by your graphics hardware.
Alan Wakes American Nightmare requires this in order to run. Please see that your system conforms with the minimum specification and ensure you have the latest...
Read moreHi there,
Yesterday I was playing some games in steam mode and everything worked fine without any error. Today when I turned my PC and start the steam this error message appeared. I don’t know what happened with my steam in less than 24h. I don’t know how to fix and I don’t want to break it more than it is at this moment, so can anyone help me to fix this and tell me why I have this error today ?
Thanks !
Steam: Fatal Error
Steam failed to load: *SteamStartEngine(0x32f660) failed with error 1:
Unable to write to...
Read moreHi Experts,
I have been unsuccessfully trying to install 3DS Max 2010 for three days now. I can launch the installer but when the installation is almost complete say nearly 98 percent, this error comes up and cannot proceed with the operation further. I have tried several times but always get this error. I tried uninstalling this partial install and tried to reinstall but this did not help either. I tried to ensure that all the 3DS products were removed by manually checking to ensure that the AutoDesk folder under my AppData in user profile and the 3DS Studio in...
Read moreHello,
For a few days I have this error with Ozzy Batman Arkham Origins when I want to play the game. It worked perfectly before this error and also, I don’t have any problem in playing this game in online mode. Can anyone tell me why I can’t play this game in single player ? How did I get this error ? I didn’t make any settings changes.
Thank you !
Message
Fatal error!
Ozzy_[2013-09-09_12.00] 297208 2013-09-09_12.00.01 (Wwise: 2012.2.1 #4427)
Game
Address z Oxf93ade (filename not found) [in C:Program Files
(x86)SteamsteamappscommonBatman Arkham
OriqinsSinglePlayerBinariesWin32BatmanOrigins.exe]
Address = 0x3819584b (filename not found) [in C:Program Files
(x86)Steamsteamclient.dll]
Address = OxSeaa8c77 (filename...
Read moreI just downloaded the Disk Image File (DMG) of GUIMiner which I will be using on my Mac OS X. However, it crashed when I attempted to launch it and it shows an error. I am getting confused since the error message has no error codes or whatsoever. I think I have re-downloaded the dmg file for few times now and still trying to launch it but it still failed. Has anyone have an idea on what the error means? If so, please help me fix it. Thanks a lot in advance!
Here is the image of the error I've...
Read more
