Archive
Hi Pro,
I installed the BW in the computer, I did not face any problem while installation. I thought everything is perfect and I am glad about it. But to my surprise I got this weird error message when I start the application. Where I can find the missing dll? How to fix the dll in desired folder? Please help. Thanks.
BW.exe - Unable To Locate Component
This application has failed to stat because ogg_tag.dll was not found. Re-installing the application may fix this problem.
OK
Read more
I have opened a .dds file with paint and I got this error. I tried to open it with Paint.Net and I got the same error. Now can I can’t open any type of images with paint and Paint.Net and it shows the same error every time. A new install of Paint.Net is not working. Can anyone help me please to fix this error message? Why and what happened when I opened the .dds file? Thank you.
C:UsersJAppDataLocalTempRar$DIa0.116banditglass.dds
Paint cannot read this file.
This is not a valid bitmap file, or it format is not currently supported.
Read more
Hello all,
I have a Sony HDD handy camI bought it last week. When I try to import a video file, I ended up with an error message. Very confused, I am not a technical person. How to get rid of this error? How to check whether this is compatible with the system? Please help me. Thanks a lot.
Windows Movie Maker
E:handycamo2-09-200720070821163510.mpg could not be imported. An interface has too many methods to fire events from
Read more
Hi Ally,
When I try to debug a code in Eclipse, I stuck up with an error message. This is not allowing me to debug. I even check the port; they are not in use by other programs. I tried with different port numbers but nothing worked. How I can solve this error? Please help me to resolve this error. Thanks a lot.
Starting GlassFish 3 has encountered a problem
Failed to connect to remote VM. Connection refused.
Read more
I have this weird error message when I try to install Paint.Net on my Windows 7 (x64). I have downloaded the software from many different sources in mane different ways but nothing seems to work. Please someone tell me from where I can download a good version and tell me why I can’t install it? What is happening with my PC and I have the same error all the time? Thank you!
System.DivideByZeroException: Attempted to divide by zero. at PaintDotNet.Setup.SetupWizard.MainImpl(String args) in D:srcpdnpdn_3_5_11srcSetupFrontEndSetupWizard.cs:line 976
Read more
Hello Expert friends,
I updated the Teamspeak 3 to latest version the installation went without any problem. But the problem triggered when I try to open the TeamSpeak 3 I got an error message that hotkey needs to be reconfigured. How to configure hotkey? I am stuck with this problem, please help me. Your help is appreciated. Thanks a lot.
Important notice
Due to the latest ts3overlay update, your hotkey needs to be reconfigured.
Please open the ts3overlay plugin configuration page and set your hotkey in the “lnput” tab.
OK
Read more
I have problem in opening the Event Viewer logs which is present under the Administrative tools of Control Panel. When I click Application, all of a sudden I am getting this Event Viewer error. I am not a technical person, feeling tired of this error. How to solve this error? Please help me to open the event logs. Thanks a lot.
Event Viewer
Unable to complete the operation on “Application”. The interface is unknown.
Read more
Hello all,
I am facing an odd error message and struggling to find the solution for it. The error triggered when I try to delete the saved state. I am just a beginner, having hard time. Account is having sufficient privilege to open attachments. To my knowledge I think I have all kind of access. Then why I get this error message? Hunting for solution please help me. Your help is really great. Thanks.
Virtual Machine Connection
The application encountered an error while attempting to change the state of ‘CentOS-V’.
‘CentOS-V’ failed to start.
Microsoft Emulated IDE Controller (Instance ID...
Read more
Clicking the OK button on the DwCC under the DMXzone Bootstrap Options results to an error even if I made some changes or not. They said, I need to define my site in Dreamweaver and clear the cache but it seems not to be working. Or maybe I am missing some important points in resolving this matter. Can someone help me? Thank you.
Dreamweaver
While executing on Click in DMXzone Bootstrap Options.htm, the following javaScript error(s) occurred:
At line 1239 of file
Read more
The error below appears when I start 3dmark06. It was working fine before but after some trouble on my machine, I was forced to wipe everything a perform a clean install including my applications. I already updated DirectX 9 but it seems like it doesn't help at all. What can you suggest? Which hardware does not support 3dmark06? Please help!
3Dmark06
Your hardware does not support the feature required to run 3DMark06.
Pixel Shader 2.0 (or higher) is one of these....
Read more
