Archive
I think my computer is having some sort of problem in handling the zip files. Whenever I try to open a zip file, I get an error message. It is not extracting the files, ends with an error. I have AVG antivirus to protect the computer, it is not blocking the zip file. What else might be the issue? How can I solve this error? Please help. Thanks.
C:UsersJohnDesktopNew_DLsCompressedMini.zip
Application not found
Read moreHi friends,
When I try to install the Windows 7 in the computer, I ended with an installation error message. I check the system requirements and I got this CD from authorized store. I followed the instructions but I got this error message. Means some files are corrupt or missing, how do I fix the missing? Which file is missing? I tried to install it several times but no luck. How can I solve this error? Please help.
Install Windows
Windows cannot install required files. The file may be corrupt or missing. Make sure all files required for...
Read moreI have a project that is based in PHP with Expression 4. When I am about to preview my page on my browser, the error below pops up. This error is new to me and I need some help on resolving this. I have spent so much of my time working on this project and I do not want to lose anything and start from the scratch again. Please let me know what will happen if I click on the Yes button in the error message.
Microsoft Expression Web
The php.ini file is not configured...
Read moreI'm attempting to watch my recordings but I am facing an error on Microsoft Expression Encoder 4. It says I need a codec to continue. I want to know if someone can send me the exact link on where I can get the required codec. Thanks.
Microsoft Expression Encoder 4 Screen Capture SP1
Microsoft Expression Encoder 4 Screen Capture Codec is not installed.
OK
Read more
Hello Folks,
When I try to uninstall EG from the computer I am facing an error message. The error states that ‘windows cannot find the file and make sure you typed the name correctly, and then try again’. I am sure about the name and then I tried to uninstall several times but nothing works. How can I solve this error? Please suggest me some solutions to solve this error. Thanks a lot.
Windows cannot find eg_videos.exe. Make sure you typed the name correctly, and then try again.
OK
Read moreWhen attempting to launch Eclipse, there is an error that says, a "Problem Occurred". When I clicked on the OK button on the error message and go to the Workbench, the error below appears. This started just today and I can't find any solutions on the Internet. I'm not sure why Eclipse suddenly became unstable. Please help me.
Internal Error
An SWT error has occurred.
You are recommended to exit the workbench.
Subsequent errors may happen and may terminate the workbench without warning.
See the .log file for more details.
Do you want to exit the workbench?
Yes No
Read moreHello tech savvy,
I use to work a lot in NetBeans to create an application, but I ended up with an error message. The error states that ‘Error in loading component cannot create instance’. I started seeing this warning error message only after java update. I tried the common method of uninstallation and installation but nothing worked. I tried to trap the error, but I can't. Help please. Thanks in advance.
Warning - Form Loaded With Errors
Error in loading component [JFramej->contentPane->nexPanel
Cannot create instance of drop.logger.NexPanel.
The component cannot be loaded.
Errors occurred in loading the form data. It is...
Read moreHi tech folks,
I think I have a problem with Eclipse; I am getting an error message when I start the Eclipse. I have Eclipse in Windows 7 64-bit operating system. It was working earlier but now I am facing this error all of a sudden. How can I solve this error? Please help me to find a solution. Thanks.
Eclipse
Failed To Create the Java Virtual Machine
OK
Read moreHello Tech folks,
When I am working in NetBeans, I was stuck up with an error message. The error message states that ‘NetBeans support of swing application Framework has been discontinued’. Do I need to install any plugin or update any drivers? How to continue the NetBeans support without interrupt? Please help me to solve this error. Thanks a lot.
Error
NetBeans support of Swing Application Framework has been discontinued. Please, use NetBeans 7.0 if you want to use this framework.
Read moreHello Pro experts,
When I try to install Eclipse, I ended up with an error message. This error irritates me a lot. Why I am not able to proceed further with installation? Any way related to plugin. Do I need to update? Asking myself too many questions, please help me to solve this error. Thanks.
Avviso
Failed to find a Main Class in "/Users/Piero/ Documents/Universita/eclipse/Eclipse.app/Contents/MacOS//../../../
plugins/ org.eclipse.equinox.launcher_1.3.0.v20 120522-18 13.jar”.
OK
Read more
