Archive
Hello folks,
When I try to establish the wired network, I stuck up with an error message. I do not have much knowledge about network just a beginner. I have Windows 2012 operating system, 8GB RAM and 250GB hard disk. Please explain me the error.Why it is happening? How I can solve this error message? Thank you.
Wired Network Policy Management
The following error occurred when saving Wired data:
There is no such object on the server. (80072030)
OK
Read moreHello all,
When I try to install the Hyperion Foundation shared services in the computer I started getting errors one after other. It being failed whatever I try to install. For your information, I have Windows XP operating system 64 bit and 500 GB hard disk. Someone could help me to solve this error. Thanks for your help.
Services
Could no start the Hyperion Foundation Shared Services - Web Application service on Local Computer. Error 1068: The dependency service or group failed to start.
Read moreHi troubleshooter,
All of a sudden, I am getting this weird error message in the computer. When I try to print a page in word document, I got this error message. I am sure the printer is connected with the computer. Even I tried through wireless but I cannot print the page. Printer is not installed via IP address. Please help me resolve the error. Thanks.
HP Officejet Pro 8600 (Network)
Unable to Communicate with Printer
The print job could not be completed because the printer is unavailable or not connected. Check your cable or wireless connection, and make...
Read moreHello.
I have pc that runs on windows 7 operating system. Recently I have installed gimp 2.8.4 on my pc. When I try to zoom in an image, gimp crashes and shows me an error. It is very urgent for me that I edit this image, so if someone knows how to solve this I will be very thankful.
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team more information.
Read moreHi Pro,
I have some problem in the computer; I am not able to browse with Internet Explorer. When I try to run the Regsvr32 command, I get this error message. I tried it several times; I even reboot the system but no luck. I have logged in has administrator, but still I am getting this error message. How can I solve this error? Please support me, thanks. Thanks in advance.
The module “C:UserssOliverDownl…VistaFolderBackground.dll” was loaded but the call to DllRegisterServer failed with error code 0x80070005
For more information about this problem search online using the error code...
Read moreHi all,
Friends I am getting this error on and off in the computer. This is very annoying to me; I am not able to listen to any music. I tried restarting the system and I even I tried to setup it again but nothing worked. Please help me. Your help is great. Thanks.
Configuring IDT Audio Driver and Applications
_ExitError Error= Device Object not present, restart the system and run setup again
OK
Read moreHello friends,
When I try to install Realtek in the computer, I stuck with an error window. In fact, the installation went almost to the end, the error triggered only when it tries to install the Audio driver. Therefore, I think the problem is with the drivers. How can I solve this error? Please help me to configure the driver for Realtek. Thanks.
Realtek High Definition Audio Driver- InstallShield Wizard
Install Realtek HD Audio Driver Failure !!
Read moreHi folks,
I successfully uninstalled the old Zobra 2.8.0 version from the computer and then I tried to install the latest version 2.9.1. I have windows operating system and I have ZAMPP too. I got this error message when I try to load the PHP extension to the folder. What might be the problem? Am I going wrong anywhere? Please help.
Warning
PHP Startup: zorba_api: Unable to initialize module
Module compiled with module API= 20090626
PHP compiled with module API= 20100525
These options need to match
OK
Read moreHi all,
When I try to install the NetBeans Package, I ended up with an error message. NetBeans IDE installer says that ‘the java SE development Kit JDK was not found in the computer’. However, I am sure; I installed it too in the computer. I do not understand why it is not able to recognize it. Please help me resolve the issue, Thanks.
Java SE Developent Kit (JDK) was not found on this computer
JDK 6 is required for installing the Net Beans IDE. Make sure that the JDK is properly installed and run installer again. You...
I got this error message, trying to find a solution in the internet but not able to find. I have attached the error please do check and help me to sort the problem. The error message says that ‘see the log files', but where I can find the log files. Please help. Thanks.
An SWT error has occurred.
You are recommended to exit the workbench..
Subsequent errors may happen and may terminate the workbench without warning.
See the log file for more details.
Do you want to exit the workbench?
Read more
