Archive
Hello Professionals,
When I open the Avira Premium Security Suite I faced an error message. This message makes me more frustrated, How to rectify this error without re-installing? The dll mentioned in the error message is not in the computer or corrupted how to install the missing dll? Please help me to fix the error, Thanks.
While loading the module (AVREG.DLL) the export function ‘DeleteRegEntry’ could not be found!
Read moreHi,
When I am attempting to change the photo image or use the Adobe reset in develop module I stuck up with an error message. Then I click ok button in the window, the photo image is not reset. I tried with all different kinds of images but nothing happens. Is this a bug? Is there any problem with the installation? Help please. Thanks.
An internal error has occurred: ?:0: stack overfow
Read moreHello there,
I am getting an error message when I am trying to drag an image control to a wpf form in Visual studio 2010. I do not understand why I am getting this error. I never experienced this kind of error on 2008 version. Is this a bug? Do I need to change any settings in the properties? Someone could help me to solve this error. Thanks for your help.
Upload Failed: Invalid URI: The Authority/Host could not be parsed.
Read moreHi all,
Friends, all of sudden I am getting a weird error message in the computer while I am working with other applications. The error message states that it is an Ajax error. However, I do not have Ajax chat box now in the computer. How I can get an error of an application, which is not in the system? Very confused, please help me. Thanks a lot.
Windows Internet Explorer
Ajax error an error has occurred in an ajax request of the chatbox, please b report your admin
OK
Read moreHello Expert friends,
I have Avira Anti-virus in my computer; it was working well without any major issue. I changed the settings to stop the ads notifications from Avira Anti-virus, after this I did not get any notification. But the problem is now I am getting this error message from the group policy. Why this error is coming up? Please help me to solve this error. Thanks.
This program is blocked by group policy. For more information, contact your system administrator.
Read moreHey friends,
I am facing a terrible problem when I uninstall an application in the computer. The problem triggered when I try to uninstall the MP3 converter, I was stuck up with an error message. I am not able to uninstall it completely. Please help me. Your help is great. Thanks in advance.
Unable to completely uninstall application.
Read moreHey,
I am getting this error message on and off in the computer. I get this error mostly when I start the computer, after a while when I run quick scan, it works fine. This error is not creating any problem, but it is very annoying. How to stop this error from popping? I tried to uninstall and reinstall the antivirus but nothing worked. Please help. Thanks.
The application module
C:Program FilesAviraAntiVirPersonalEditing Premiumrcimage.dll
cannot be found or has been modified or destroyed.
The AVWSC.EXE cannot be started.
Please check your installation!
Read moreHi tech experts,
Recently When I try to updateWindows Media Player to the latest one, I ended up with an error message. The error says that ‘Windows Media Player is not installed properly and must be reinstalled’. I tried several times to reinstall but nothing happens. So I cannot update the media player, please share your idea. Thanks in advance.
The file wmploc.dll has a version number of 11.0.6001.7000 where 11.0 .6002.16489 was expected.
Windows Media Player is not installed property and must be reinstalled. Do you want to install the Player from the Microsoft Web...
Read moreHello trouble shooters,
I am in the critical situation, facing an unknown error. When I run the full scan in Avira Antivirus it went without any problem, No virus found. But all of sudden a pop up window appeared with an error. I am not aware of this error before, how to solve this error? I tried to trap the error, but I can't. Help please. Thanks in advance.
C:WindowsWinSxSx86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16661_none_420fe3fa2b8113bdCOMCTL32.dll is either not designed to run on Windows or it contains error. Try installing the program again using the original installation media or contact your system administrator...
Read moreHello folks,
I am not a technical person; this error makes me frustrating and I am tired of this error. I am getting an error message when I am trying to play a video from DVD. I tried it play several times, I check the DVD it is perfect and able to play it my laptop. However, why do I get this error in the computer? Do I need to change any setting to support the player? Please help. Thanks.
Windows Media Player cannot play the DVD. The disc was created in a manner that...
Read more
