Archive
Hi experts,
After I connected my iPhone to my laptop this error message. I am a novice with PCs I don’t really know what it means and how this error can be solved. Does any can help me please to solve this error? What this error means and why I have this?
Thank you!
iPCU.exe - Entry Point Not Found
The procedure entry point CFHTTPMessageSetHeaderFieldValue could
not be located in the dynamic link library CFNetwork.dll.
OK
Read more
Hello there,
Today I reinstalled my Windows 7 (x86) on my laptop and I have this problem installing iTunes. I have downloaded a few different versions from different servers but I can’t install it. It worked just fine before I reinstall the Windows. Can anyone help me to install iTunes? Please tell me the steps to install and if possible provide me a good installer.
Thank you!
iTunes
There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor.
OK
Read more
Hello there,
This morning this error appeared when I opened Winamp Player to listen some music. Last night it worked just fine and now this error confused me a bit and I don’t know what to do. I click NO and the Winamp is not opening anymore. What would happen if I click Yes? Is this an error and I should be worried about? Thank you!
Audio Enhancements Problem
Windows has detected that audio enhancements for the following device are causing problems:
Speakers (Realtek High Definition Audio)
Would you like to disable Driver Enhancements for this device ?
Yes No
Read more
Hi there,
When I turned on my scanner and tried to scan a picture this error appeared on my desktop. Also I have reinstalled the drivers and still is not working and I don’t know what might be wrong with my scanner since the last time I’ve used it there was no problem with the scanner. Can anyone help me please to solve this ? Does my scanner need a hardware reparation ?
Thank you !
TW-Brother MFC-589CN LAN Scanner
Failed to connect to the device.
- If the device is OFF, turn ON the device.
- Check the I/F cable...
Read more
Hello there,
After I installed Themida on my PC I got this error when I want to run it. I reinstalled the software again but it seems like doesn’t want to work. I don’t know how to solve it so please can anyone help me to fix this? Why I have this error?
Thanks!
Themida
Cannot find ‘X3DAudio1_6.dll. Please re-instaII this application
OK
Read more
This morning I tried to run Visual Studio but suddenly this error popped-up. The software worked fine yesterday and I am a little bit angry to this error. I reinstalled the Visual Studio and worked just fine until I rebooted my laptop. Does anyone have any idea how this error can be solved? Please help!
Thank you!
Microsoft Visual Studio
Unable to start program “Windowstaskhost.exe”.
The drive cannot locate a specific area or track on the disk.
OK
Read more
Hello experts,
After I installed Football Manager this night, when I tried to open it this error message box sadly stopped me.  I reinstalled the FM and still this error. I didn’t delete any DLL files from my PC so I don’t know why I have this error. Can anyone help me to fix this error? Why I have this error and how can I prevent it to appear in the future?
Thanks!
FMexe - System Error
The program can’t start because saAudit2005MT.dII is missing from your computer Try reinstalling the program to fix this problem.
OK
Read more
As this error say the problem is with the add-ons that I have installed on my Outlook. But the real problem is that I don’t remember installing anything on my PC lately, so I don’t see the point of this error. Does anyone have any idea why I have this error message? Please help me to fix this one…
Best regards!
Microsoft Outlook
Outlook experienced a serious problem with the ‘Microsoft exchange add-in’ add-in. If you have seen this message multiple times, you should disable this add-in and check to see if an update is available. Do you want...
Read more
Hello experts,
Recently I made some changes in my Windows hoping my PC will run better and I will get better performances. It worked fine for two days when this morning I got this error. I press OK and this error appear again and again. I did some researches on the Internet I found nothing. Can anyone help me to fix this please without reinstalling my Windows? Can this be solved without losing any data?
Thank you!
Bad data in imatest.ini. Please remove.
Error parsing the file for keys:
C:UsersNormanAppDataRoaminglmatestimatest.ini: Error using ==> infile>findkeys at 508
unknown string found at line 2
The...
Read more
Hi there,
After installing Crystal Reports and rebooted the PC as it requested I got this error message box when I want to open it. I had the same error with other software’s and because of that I ran a DLL fixer and I solved these error for the moment. It seems like it couldn’t fix this missing one DLL. Can anyone help me to fix this kind of errors? Why DLL fixer didn’t fix this kind of error?
Thanks!
A Crystal Reports error has occurred.
Error 104
Failed to obtain Version Information from CRPE32.DLL - Getcrpeversion <GetVersionlrto>...
Read more
