Archive
Hi there,
This morning when I tried to open Opera browser this error message. I was a bit surprised because last night it worked just fine and now with this error I cannot access my Internet. Also the reinstall is not working and the same error appears. Can anyone help me please to solve this Opera error ? If this cannot be solved please recommend me another GOOD browser.
Thank you !
‘/home/dspider/.wine/drive_c/Program’No such file or directory
OK
Read moreHello,
Today this message appeared on my desktop about Profile storage space. I don’t know how to check how much space I have left or how much space is busy. Can anyone help me to check and if is possible please tell me more about this.
Thanks !
You’ve exceeded your Windows Roaming Profile Quota. Run: ECN HELP -> Clean My Profile. If this doesn’t reduce your profile enough, see KB article “Windows Roaming Profile” @
“http://engr.purdue.edu/ECN/profile”.
Read moreHello there,
After I finished to work with TeamViewer 7 this error appeared and I don’t know what ID is missing. When I want to connect with another PC this error appear again. How do I fix this ? Also the reinstall of TeamViewer is not working and please tell me what is causing this error message ?
Thanks !
TeamViewer
TeamViewer
The TeamViewer VPN adapter is not installed on your computer. This adapter is required in order to create VPN connections. Administrative rights are required in order to install the TeamViewer VPN adapter.
OK
Read moreMeGUI worked fine until I tried to update it. During the update this error appear and stopped the processes. I tried to reinstall the program and now is not working at all, I have totally messed up the program. Can anyone help me to solve this? Please help me to reinstall and update the program step by step. Thank you!
MeGUI 0.3.1.1016
Fatal error
MeGUI encountered a fatal error and may not be able to proceed.
Reason: Atkomst till sokvagen D;ApplicationMeGUInekas. Source of exception: mscorlibstacktrace: vid Dystem.IO._Error.WinIOError(Int32errorCode, String maybeFullPath)
Vid.System.IO.Directory.InternatCreateDirectory(String fullPath,String path, DirectorySecuritydirSecurity)
Vid.System.IO.Directory.InternatCreateDirectory(String Path,String path, DirectorySecuritydirSecurity)
Vid MeGUILUpdateWindow.SaveNewFile(iUpgradeable file, Stream data)
Vid...
Read moreHello,
I have message and I don’t understand why the installer cannot run on this mode. Is my first error of this kind and I don’t have any solution for. Can anyone help me to fix this one ? What could be the problem with this Installer UI Mode Error ?
Thank you !
Installer User Interface Mode Not Supported
The installer cannot run in this UI mode. To specify the interface mode, use the –i command-line, followed by the UI mode identifier. The valid UI modes identifiers are GUI, Console, and Silent.
OK
Read moreHello experts,
I've bought a used LS-XHL which has no hard disk. I've got two HDDs which I want to install in the NAS. Unfortunately updating the firmware with LSUpdater does not succeed. I searched many hours on this website and others but didn't find a solve for this error. Can anyone help me to fix this error ?
Thanks !
LSUpdater
Couldn’t confirm response from LS-CHL-V2-EM856.
Please check a network address if both PC and LS-CHL-V2-EM856
Please disable the Firewall function if it is working on PC.
Updating is aborted.
OK
Read moreHello,
I have this error from Realtek AC’97 Audio when I try to install the new updated version of this program. Now I have this error when I want to install the old version from CD driver. It seems like I broke for all my audio settings. Does anyone have any idea why I can’t install the new and old version of Realtek AC’97 Audio? Thank you.
Realtek AC’97 Audio
Realtek AC’97 Audio
An error (-5009 : 0x80040707) has occurred while running the setup.
Please make sure you have finished any previous setup and closed other applications. If the error...
Read moreI am having an error with iTunes. When I tried to upgrade it, it shows an error as shown below:
ITunes
ITunes was not installed correctly. Please reinstall iTunes.
Error 7 (Windows error 127)
OK
I uninstalled iTunes and attempt to reinstall it back. However, the same error appears. How can I fix this?
Read moreHello,
Today I install Android Studio on my laptop and when I tried to open it this error stopped my action. I followed the instruction in the error I nothing was found. I downloaded and reinstalled the Android Studio and same error appeared. Please is anyone available to help me with this error? I did something wrong when I installed Android Studio?
Thank you!
Error launching Android Studio
Failed to load JVM DLL C:Program FilesJavajdk1.7.0_25jre.
If you already have a 32-bit JDK installed, define a JAVA_HOME variable in Computer> System Properties> System Settings> Environment Variables.
OK
Read moreHello,
When I rebooted my PC this morning because it was very slow, this error message appeared on my desktop. I didn’t make any changes before reboot. I would like to know if anyone can help me please to solve this error without reinstalling my Windows. What happened to my PC and what is causing this error?
Thanks!
Entry Point Not Found
The procedure entry point QT_Thunk could not be located in the dynamic link library kernel32.dll. OK
Read more
