Archive
Hello guys,
Every time I try to connect to the Internet this error message appears on my desktop. I click OK and my connection get lost. I reinstalled my Windows for this error and I am angry because I still have it. Can anyone of you experts can help me solving this error? What is happening with my PC?
Thanks!
Error Starting Program
A required .DLL file, OLEACC.DLL was not found
OK
Read more
Today I experienced an unpleasant error and I stuck with it. No idea why and how can this be solved. I have no idea what is causing it since yesterday all worked just fine. Is anyone there that might have a solution for my error? Can’t this error be prevented in the future?
Thank you!
Unexpected exception
Access Violation
File – C:Windowssystem32KERNEL32.dll
Offset – 0x0004d0b7     Line 740
Read more
Hi experts,
Recently installed a new game on my PC and I have this error about it. I have lots of games installed on my PC and this is only one with errors. I tried in many ways to fix this but no result for me and my game. How can I solve this game error? Why this is the only game that have errors?
Thanks!
The application or DLL C:WINDOWSsystem32d3d8.dll is not a valid Windows image. Please check this against your installation diskette.
OK
Read more
I have this weird error from QuickBooks and I cannot solve it at all. I have rebooted my laptop many times, no result, I have reinstalled the software, no result, asked my friends for any solution, no result and one of my friends told me that I should ask you for solution on this website. So, does anyone have any idea how can this be solved? Please tell me why I have this error no one else have it?
Thanks!
Error
Problem: There was an unexpected error reported trying to run QuickBooks while with company file
Solution: This should only...
Read more
Hi there,
I have this error that appears on my desktop every time, unexpectedly and for no reason. Sometimes when my PC is open and none application are opened this error still appears. I am tired of this error and I want it to be solved by the experts from Techyv. Please guys can anyone help me to fix this? Why I have this error and how can I prevent such errors?
Thank you guys!
RunDLL
There was a problem starting msilbk32.dIl
The specified module could not be found.
Read more
Hello experts,
Recently I experienced some errors and crashing from Microsoft Outlook. It works hard and full of errors but I am glad that I can still use it. Now I am tired of all of these errors and I want them out from my Outlook. Please Techyv help me fixing this error. What is the best solution to get rid of all of these errors?
Thank you!
OutllookPlugin
The InstallShield Engine (IKernel.exe) could not be installed.
IKernel.exe could not be copied to C:Program FilesCommon FilesInstallShieldEngine6Intel 32’.
Make sure that you have the appropriate privileges to copy files to this folder. (0x20)
OK
Read more
Hi there,
Recently I made an update to my Windows 8 to Windows 8.1 and I have this error about Framework. I have installed the latest version of Framework manually and I still have this error. I did some researches on the Internet and it seems like no one solved this. Is there anyone on Techyv that can help me please?
Thank you!
Sorry, something went wrong
An error occurred during the compilation of the requested file, or one of its dependencies. Could not write to output file c:WindowsMicrosoft.NETFramework64v4.0.303 19Temporary ASP.NET Filesrootd9bc15df5100559fApp_Web_managefeatures.aspx.9c9699a8.463q7eql.dll The directory name is invalid.
GO BACK TO SITE
Read more
Hi there,
When my Windows 7 (x86) is starting I have this error message box appears. I don’t know what error I should reinstall to fix this error, nothing happens when I click OK but I am a little bit worried. Does anyone have any idea how can I solve this error? Is something wrong with my Windows 7?
Thank you!
STService.exe - System Error
The program can’t start because STLog.dIl is missing from your computer. Try reinstalling the program to fix this problem.
OK
Read more
Hi there,
After I installed some software on my PC and rebooted the system I got this error. I pressed OK and everything is fine. The problem is that I have this error every time I open my PC. I have copied the DLL in my Windows folder and still, I even uninstalled the game and still the error popped-up. What is this DLL error? How can I solve this?
Thank you!
rstrui.exe - OrdinaI Not Found
The ordinaI 481 could not be located in the dynamic link library Iertutil.dll
OK
Read more
I have installed on my laptop with Windows 7 (x86) Paladin DesingBase version 5.0. When I tried to open it this error message box appeared and the software closed. I have some friends with PCs (not laptops) and this software is running just fine without any error. Please help me to fix this error. Why I am the only one with this error?
Thanks!
Actrix.exe - System Error
The program can’t start because GX6050R.dII is missing from your
OK
Read more
